Sponsored by: CARiD
95' classic Range rover ABS pump fault
Old Feb 20, 2007 | 04:30 AM
dumellarah's Avatar
5th Gear
Default 95' classic Range rover ABS pump fault
Hello, I have finally traced a fault in the ABS system back to the electric pressure pump. The problem seems not to be the pump motor itself but the plug in sensor that ismounted into the top of pump housing directly below the high pressure line to the accumulator. Dose anyone know where i can find one of these and how i go about changing it or where i could find a new pump motor complete as a replacement.
Old Feb 20, 2007 | 10:34 AM
Default RE: 95' classic Range rover ABS pump fault
You might want to talk with these guys if you decide to get another pump assembly,
http://www.roverlandparts.com/index.asp
Mike
Old Mar 3, 2009 | 07:13 PM
rangerover95's Avatar
Default abs pump failure
hey i have a 95 rover and the same thing happend that abs pump is expensive i just could not afford it so i found someone who could rebuild the pump and put new relays he put a one year warenty on his work if you want his number email me at hawk_nicholas@yahoo.com
06Range
May 8, 2013 09:01 PM
jmason
Mar 12, 2013 08:08 PM
MrBrooks
Jun 11, 2010 09:25 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
