Range Rover starts then dies
Old Jan 6, 2009 | 08:17 PM
bambam84105's Avatar
4th Gear
Default Range Rover starts then dies
I have a 1996 RR that I haven't drove in about 5 months. I have recently tried to drive it but is keeps dieing. I will start the car and it will run ok for 1 to 2 minutes and the start to die. I try and give it a bit more gas and it struggles then dies. I wait 1 minute, and try starting it again. It will try to run for up to 5 seconds the die again. If I wait for an hour or so to try starting it again, it will do the same thing, run for a few minutes the die.
Any suggestions?
Old Jan 6, 2009 | 10:06 PM
ggothlin's Avatar
Default RE: Range Rover starts then dies
The gas sitting in the tank for 5 months can get unstable.
How much of this old gas is in your tank? 1/4 or 1/2?
Old Jan 6, 2009 | 10:23 PM
4th Gear
My tank is about 1/4 full
Old Jan 6, 2009 | 11:05 PM
ggothlin's Avatar
I would definetly buy a can of gas stabilizer and also fill up a 5 gallon gas can with premium and put that in the tank to start with.
Was it running just great 5 months prior?
Old Jan 7, 2009 | 01:28 AM
4th Gear
Yes, I had no problems. I will try buying the stabilizer and 5 new gallons of gas,
Old Jan 7, 2009 | 07:54 PM
4th Gear
Should I try and siphon as much of the old gas as I can out prior to adding the new gas?
Old Mar 20, 2012 | 02:39 PM
Sonnie2326's Avatar
Default ?
HI, I was wondering if you ever fixed the problem? My 96 RR is doing the exact same thing. I'm thinking it's some sort of a sensor.
Ad!
Aug 18, 2021 07:30 AM
Range Rovin
Jun 8, 2012 11:04 PM
bubba_78363
Dec 14, 2011 11:25 AM
mapesw
Sep 30, 2010 03:34 PM
noyz25
Freelander
Jan 15, 2010 06:01 AM
