Rear rotor part missing is important or cosmetic?
Old Apr 30, 2014 | 12:06 AM
rsw's Avatar
rsw
3rd Gear
Default Rear rotor part missing is important or cosmetic?
I have a 2008 Range Rover Sport. My mechanic replace the rear pads and rotors. The rear rotors have a hole that you can insert you screw driver into so you can adjust the tension of the shoes. When I returned home after the repairs were complete I saw the cap that covers this hole is missing. Is this something that I need to go back to have dug out of the dumpster or is this part more for cosmetic purposes?
Old Apr 30, 2014 | 07:26 AM
drowssap's Avatar
The rear rotors have a hole that you can insert you screw driver into so you can adjust the tension of the shoes. there is no adjustments on disc brakes but if there is a dust cover off it should be replaced
Old Apr 30, 2014 | 11:48 AM
04duxlr's Avatar
The RR Sport has the parking brake shoes inside the rotors. That plug is mostly cosmetic, but since the parking brake on those things is prone to corrosion related failures I would ask for the plugs. If they have lost them, have them order new ones for you.
Old Apr 30, 2014 | 12:45 PM
drowssap's Avatar
my mistake; i did not know they using the rear brakes, i always liked locking the drive shaft
Old Apr 30, 2014 | 03:32 PM
04duxlr's Avatar
It's electronic to boot, so they're prone to failure. Apparently using a lever is too plebian in the designer's eyes.
brandonjayjones
Sep 25, 2012 08:29 AM
willlane
Dec 6, 2011 09:40 AM
Jorover
Jul 6, 2010 10:38 PM
mag48
May 16, 2009 05:23 PM
Sid1
Oct 25, 2006 01:36 PM
