RR Classic overheating prob. Help!!
Old Oct 10, 2005 | 07:16 AM
Ash A's Avatar
Default RR Classic overheating prob. Help!!
Hi i'm new on here and hoped you could give me some advice!
I have a L reg Classic, (3.9 V8 gas converted). It has had the head gaskets done and heads skimmed (they needed doing!), but its still overheating!
It is getting up to the normal running temp (just below halfway) within about 4 miles, it then sits there and starts creeping up again after about 10 miles. It makes no difference if you hammer the car or drive steady, and once it starts to get hot if you stop and let it tick over the temp goes back down.
All the pipes seem to be hot and the heaters are fine, the thermostat has also been checked.
Any ideas? Thanks in advance!
Old Oct 11, 2005 | 10:04 PM
rinmud's Avatar
Default RE: RR Classic overheating prob. Help!!
i might be full of **** but i would replace radiator and t stat
Old Nov 1, 2005 | 05:36 PM
scrappyike's Avatar
thermostat was the problem for me. Same symptoms. Good luck
Old Nov 15, 2005 | 01:38 AM
kylle08's Avatar
i think you better get radiator and thermostat a replacement. i got my replacement for my radiator at a discounted price from carpartswholesale.com.. you might want to check it and find other parts that you might need.. good luck
Newbie1989
Jan 17, 2011 07:32 PM
ALAKDisco
Dec 18, 2010 10:24 PM
brandodisco
Defender
Jan 25, 2008 12:26 PM
Bigmonty
Dec 20, 2007 04:34 PM
Classic89
Aug 23, 2007 04:06 AM
