RRC Diagnostic help
Old Apr 18, 2012 | 05:40 AM
drowssap's Avatar
Default RRC Diagnostic help
i have a 90 RRC that the check engine light came on this morning. Also my PC is down so im stuck using a laptop almost as old.
Can someone walk me thru the on board dianostics, i think you have to turn the key in a special sequence in order for the black box under the passenger seat to give up the code.
also a link to the codes would be helpful, i have it all on my PC but cant get to it.
thanks
Old Apr 18, 2012 | 06:59 AM
See this resource: Land Tover Troubleshooting: retrieving fault codes
See Land Rover Manuals for on line manual - no download needed.
Old Apr 18, 2012 | 08:24 AM
drowssap's Avatar
thank-you sir
Old Apr 18, 2012 | 08:37 AM
hilltoppersx's Avatar
$10 says its an EFI code.
Old Apr 18, 2012 | 09:03 AM
drowssap's Avatar
02 is the only code
Old Apr 19, 2012 | 08:15 AM
Paul Grant's Avatar
Code 2:
This code means power to the ECU has been disconnected and the truck has not yet been started. This code should go away as soon as the vehicle is started for the first time. Appearance of this code while driving may signal a problem within the ECU.
If you want to try another ECU drop me an email or call. I can always send one up to you to see if it helps. If you contact me before noon I can get it out today and you'll have it tomorrow.
Cheers,
Paul
Old Apr 19, 2012 | 08:25 AM
drowssap's Avatar
Default thanks for the offer
but i got a spare from that 4.2 your were parting, when i came to visit you. if the light comes on again i'll throw that in and see if if it cures it.
paul, if you doing another rrc i need a ac condensate drain pan.
Jim
WNYErikDiscoII
Nov 7, 2013 09:32 AM
Lincoln Tarantino
May 2, 2012 11:20 AM
Paul Grant
36
Mar 14, 2012 07:59 PM
salve7
Mar 19, 2009 01:03 PM
