RRC no heat
Ok, that's good info. So in that case, I think my ac fan is working great! However I can't get it to shut off and my heater fan to turn on. When I turn on the blower (bottom right **** that slides right to left) it only operates the ac fan. Is there anything I can do about this?
When you're trying to get heat, where do you have the lower left switch positioned? The A/C blower should only be on when you have the lower left switch on the blue snowflake icon. If you move the lower left switch to the red icon along with moving all the other switches to their red icons you should have maximum output for the defrost position. Move the right side switch to the icon that depicts a shoe and you'll be getting heat.
Edit: In the above post I was actually referring to the vertical lever all the way to the left. THe horizontal leverat the bottom left also moves side to side and doesn't change a thing. The fan stays on and blows cold through the dash vents.
WNYErikDiscoII
11-07-2013 09:32 AM
Lincoln Tarantino
05-02-2012 11:20 AM
Paul Grant
36
03-14-2012 07:59 PM
idahorover
02-12-2011 01:39 PM
