RRC no heat
Old Mar 2, 2015 | 12:30 PM
Paul Grant's Avatar
Originally Posted by mtrdrms
Ok, that's good info. So in that case, I think my ac fan is working great! However I can't get it to shut off and my heater fan to turn on. When I turn on the blower (bottom right **** that slides right to left) it only operates the ac fan. Is there anything I can do about this?
When you're trying to get heat, where do you have the lower left switch positioned? The A/C blower should only be on when you have the lower left switch on the blue snowflake icon. If you move the lower left switch to the red icon along with moving all the other switches to their red icons you should have maximum output for the defrost position. Move the right side switch to the icon that depicts a shoe and you'll be getting heat.
Old Mar 3, 2015 | 07:52 AM
mtrdrms's Avatar
Thanks Paul. I think you are on to something here. When I move the lower left lever between its upper and lower positions, it offers a lot of resistance and doesn't change a thing. The fan still blows from the vents and not the defrost. Any ideas?
Old Mar 3, 2015 | 04:21 PM
mtrdrms's Avatar
Edit: In the above post I was actually referring to the vertical lever all the way to the left. THe horizontal leverat the bottom left also moves side to side and doesn't change a thing. The fan stays on and blows cold through the dash vents.
jmason
Nov 17, 2013 06:39 AM
WNYErikDiscoII
Nov 7, 2013 09:32 AM
Lincoln Tarantino
May 2, 2012 11:20 AM
Paul Grant
36
Mar 14, 2012 07:59 PM
idahorover
Feb 12, 2011 01:39 PM
