Sea Foam
Old Mar 17, 2009 | 11:16 AM
LRScott's Avatar
Default Sea Foam
I would like to put some sea foam in my fuel tank but, before I do. Does anyone know how much I should put in and whether it is safe for the GEMS engine?
Thanks in advanced!
Old Mar 17, 2009 | 09:52 PM
skyguy's Avatar
This sounds like a question for Disco Mike.
Old Mar 24, 2009 | 01:10 PM
hunkojunkhotrods's Avatar
If you use the Seafoam, expect a bit of white smoke for a while (depending on how much carbon is built up). It SHOULDN'T harm the engine. I prefer using Berryman's Fuel System cleaner. It's a three part kit: 1. throttle body cleaner spray, 2. upper intake cleaner 3. fuel system cleaner.
1. spray directly into throttle body to dizzolve the gunk behind the throttle plate.
2. hook up to a source of vacuum on intake plenum and sucks out of the can with engine running (you'll get huge ammount of smoke but kill all mosquitos within a mile) this cleans the creosote out of the upper plenum and off the back of the intake valves.
3. pour into the fuel tank. This cleans and lubrucates injectors.
I have used this on several high mileage (non rover) vehicles and it works wonders. I have used it on both ECU and non-ECU equipped engines. The only trick is the MAF metered engines and the throttle body spay (you need someone to keep the engine running at RPM).
Occasionally, it tripped a check engine code, but it stayed off once reset.
The kit (in Florida) is about $25.
bigugly82
Mar 14, 2018 05:09 PM
DeepBlueWater
Oct 16, 2007 10:23 AM
Camdisco24
Aug 7, 2007 04:44 PM
mowthat
Feb 14, 2007 10:03 PM
mikemeyer0
Jun 16, 2005 04:00 PM
