Spare Tire Hoist Jammed
Old Mar 4, 2017 | 02:15 PM
clayrn's Avatar
Default Spare Tire Hoist Jammed
2010 LRS 66K Miles
The hoist cable will extent a few inches, then jams tight...
Old Mar 4, 2017 | 05:17 PM
clayrn's Avatar
Default who knew..?
Apparently this can happen when you wind the winch without putting tension on the cable.
Attaching a repair description posted by a gentleman from Australia.
File Type: pdf
Old Mar 5, 2017 | 12:44 PM
clayrn's Avatar
After a day of struggling, a friend set up a block and tackle and we were able to extract the cable. One of the strands broke, but there are plenty left to hold up the doughnut.
Old Mar 5, 2017 | 02:05 PM
OverRover's Avatar
This is a very common problem in most vehicles with under mount spare tires. Part of the issue is corrosion/gunk on the cable, but also the cable gets twisted and stuck. If you didn't replace the hoist (if you didn't you will), I hope you lubed the cable very well.
The hoist LAND ROVER RANGE ROVER SPORT LR3 LR4 SPARE TIRE WHEEL WINCH MECHANISM LR024145 | eBay is inexpensive and very simple to install. Good Luck!
Old Mar 8, 2017 | 04:07 PM
clayrn's Avatar
Thanks for the link OverRover... there are a lot of varieties out there for sure...
Old Feb 18, 2020 | 08:15 PM
wish76's Avatar
Thank you for this! I would tell you how much time you saved me but I really can't even begin to guess that.
jastutte
Dec 9, 2016 05:59 PM
0304Disco
Sep 25, 2013 09:32 AM
Discolife
Jun 10, 2012 08:22 PM
shawn
Audio/Visual Electronics
Nov 8, 2007 12:52 PM
willlane
Aug 29, 2007 01:22 AM
