Start up lights?
Old Jun 1, 2007 | 10:03 AM
bonedoc's Avatar
Default Start up lights?
When I start the 93 rover, the warning lights come on as a test after startup. They seem to stay on a long time and the oil light flashes, but they all go out at the same time. Is this normal?\
Old Jun 1, 2007 | 12:32 PM
geoman's Avatar
Default RE: Start up lights?
Normal for the ABS and Brake light to come on--- they go off after you roll. The flashing oil light probably means it is time to do a engine flush as you have sludge build up inside the engine.
Get a new oil filter and6 quarts of good quality oil, such as Valvoline, and one quart of RISLONE (a very good additive for older engines). Also buy 6 quarts of ATF (automatic trans fluid). Drain your existing oil after warming up the engine. Put the 6 quarts of ATF in the engine and start it up. Let it idle for 40-60 minutes--- but DO NOT DRIVE IT-- with the ATF in. Drain the ATF, replace the oil filter, and put in the Valvoline and Rislone.
regards,
Geoman
www.eurotekapg.com
snads
Dec 6, 2014 02:42 PM
dmatranga
Feb 5, 2013 12:27 AM
vtec2403
Jan 30, 2013 05:27 AM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
