transmission fluid check?
the fill plug is on the right hand side above the rear corner of the pan it takes a 8mm allen to open it,
check this level with the engine running and the trans at temp. After you have put the selector through all of the gears
in other words dont open the plug till these conditions are met or you may have a gusher.
Find out where the leak is coming from it might be a loose cooler line connection dont over tighten the banjo bolt if it is a cooler line
