transmission fluid check?
Old May 9, 2011 | 10:09 AM
pizzaboy's Avatar
Default transmission fluid check?
Can anyone please tell me how to check tranny fluid? If i dont drive car for a week it leaks a good size puddle. Not a drop when i drive daily. THANKS
Old May 9, 2011 | 12:09 PM
LRScott's Avatar
Year of the range rover would help. The 95 to 99 used a dipstick, 99 to 2002 they used a fill plug.
Old May 9, 2011 | 01:06 PM
Chris X's Avatar
If you have the 95-99 with the dipstick, it actually tells you on the dipstick itself how to check it properly.
Old May 9, 2011 | 07:52 PM
pizzaboy's Avatar
Sorry guys. I have a 2006 RR.
Old May 9, 2011 | 08:45 PM
krazzz's Avatar
If a 2006 is leaking that much you may have some big problems. That is way too early to leak like that. I don't know for sure but you most likely have to get underneath and find the fill plug to check the fluid.
Old May 10, 2011 | 09:30 PM
Mrmerlin's Avatar
the fill plug is on the right hand side above the rear corner of the pan it takes a 8mm allen to open it,
check this level with the engine running and the trans at temp. After you have put the selector through all of the gears
in other words dont open the plug till these conditions are met or you may have a gusher.
Find out where the leak is coming from it might be a loose cooler line connection dont over tighten the banjo bolt if it is a cooler line
Old May 11, 2011 | 06:56 AM
pizzaboy's Avatar
Thanks Mrmerlin!
dirtlord
Jul 5, 2015 05:57 PM
FlyingZebra34
Feb 22, 2014 05:39 PM
mirepoixmatt
Dec 26, 2013 12:19 PM
hriant88
Aug 6, 2013 05:09 PM
varlean
Freelander
Dec 18, 2011 09:30 AM
