transmission overheat message appears on p38
Old Sep 4, 2011 | 02:41 AM
LRScott's Avatar
The bottom line is there is a restricted flow of ATF somewhere which is making the system not only overheat, but seep out of low pressure areas. It could be your cooler lines or the transmission radiator. It could also be due to old age, it happens (btw, you never did tell us the year or mileage on your rover). It could also be the valve block on the transmission. In either case, you may be looking at a new/rebuild of your transmission, unless you can find where blockage is occurring. You might even consider your torque converter. You are looking at an expensive repair. Wish you the best and hope it works out.
Old Sep 11, 2011 | 02:47 AM
peter r's Avatar
6th Gear
Default p38 transmision problem 1998 model 120,000 mls travelled
Hi , have problem with fluid leaking out of automatic transmission breather and dipstick when driving , any ideas out there to problem ? appreciate any help, thankyou Peter
Old Dec 30, 2022 | 08:08 AM
yoni55's Avatar
Default transmit ion over heating
my P38 2001 with less than 100K /Km. has a problem.
when starting the car within 2 or 3 minuts transmition over heat warning light goes on and turns off after 5 to 6 minuts
what should i look for ?
jonathan
shrink
Feb 8, 2012 08:40 PM
byrona8
Mar 16, 2010 10:09 PM
range_rovin1986
Mar 29, 2007 06:43 PM
