Transmission problem
Old Jun 4, 2011 | 10:02 PM
idahorover's Avatar
Default Transmission problem
I have a 1995 RRC. When you first start it up the tranny seems fine. When you drive it for about a mile it starts acting up, like it's running out of fluid. If you stop it won't go any more in any gear and it makes a noise that seems like it's coming from the bell housing. If you put it in park or neutral the noise dies down and starts up again if you put it in any gear. Now if you turn the key off, then start it again it will go into gear somewhat, but the noise is back and fairly loud still. When I pulled the oil pan there was black sludge stuff all over the magnets, so I'm assuming it's metal. Any way was just wondering, if it's toast or something easy.
Old Jun 4, 2011 | 10:53 PM
LRScott's Avatar
Well, the good news is... Classic trannies are not to hard to find for cheap . It could be a seal issue. At least that is what it sounds like to me, although the noises kinda get me. You could run some of that magic tranny fix stuff in there. Probably won't work, but you never know. The other thought is maybe the torque converter... In any case, this doesn't sound like a simple fix.
On a side note, the black sludge on the magnet is normal. I recently did a flush on one of my other rigs and saw lots of goop on the magnet, just part of it. Metal shavings are what you want to look out for.
Old Jun 5, 2011 | 07:45 AM
Your tranny is shot, good ones are not cheap but can be found. Better start looking for a good rebuild shop cause even a good 17 year old tranny should be gone thru before reinstalling.
Old Jun 5, 2011 | 09:53 AM
idahorover's Avatar
Ok thanks, I figured it was shot, but there's always hope. I have another one I will replace it with, till I get that one rebuilt. Thanks
Tanrover
Dec 6, 2006 01:15 AM
cterrebonne
Oct 4, 2006 08:05 PM
MCA
Oct 4, 2006 01:45 PM
Grtis1
Aug 7, 2006 03:32 PM
basquiat
Jun 8, 2005 12:17 AM
