transmission problem
Old Oct 2, 2006 | 09:34 PM
cterrebonne's Avatar
Default transmission problem
i have a series 1 and currentyly i am redoing the engine because of a over heat issue and very low compression due of. . the second issue is that before the engine died my transmision would seem to slip a lttle in drive then catch fine but if you dropped it into 1 there would be no slippage or any problems.. any ideas
Old Oct 3, 2006 | 12:07 AM
Strider's Avatar
Default RE: transmission problem
It is most likely time to re-build the tranny. I had the same poblem with my 95 and ended up re-building it. I hope you have deep pockets
Old Oct 3, 2006 | 10:27 AM
How many miles on your truck, how often do you change the ATF, what does the fluid level look like and does it smell burned???
Mike
Old Oct 3, 2006 | 05:49 PM
150,000 last service was at 117,000 and the level should be correct but i dont think it smeels burt...when you say rebuilding what that invlolves?
Old Oct 4, 2006 | 11:48 AM
ORIGINAL: cterrebonne
At your mileage, yes you may be looking at get a rebuilt tranny or having your rebuilt, depending on what is cheaper.
Before I would do that I would change the fluid, not the filter and add a bottle of Lucas tranny additive, drive it for a week, if nothing changes then it is safe to say your tranny is dying.
A rebuilt or exchange tranny is one that has had all it's internal wear parts replaced like seals clutch plates valves and or soloinoids replaced along with a rebuilt torque convertor.
Mike
Old Oct 4, 2006 | 04:17 PM
yeah thas what i figured when you said rebuild.....when i get my engine aquared away i'll try the lucas approach. you wouldnt happen to know how much a rebuild runs?
Old Oct 4, 2006 | 04:49 PM
If you shop around you can find rebuilt trannys for around $1700 and up plus shipping and labor to install which would be $500 to $700.
Mke
Old Oct 4, 2006 | 08:05 PM
yeah that doesnt sound horribly bad......im betting i could do the swap though
JMG03
May 5, 2007 11:55 AM
Tanrover
Dec 6, 2006 01:15 AM
MCA
Oct 4, 2006 01:45 PM
Grtis1
Aug 7, 2006 03:32 PM
basquiat
Jun 8, 2005 12:17 AM
