Truck sits at a strange angle... sometimes..
Old Aug 21, 2010 | 01:07 PM
Vertigo RT's Avatar
Default Truck sits at a strange angle... sometimes..
I just wanted to thank you guys again for helping my narrow down my MAF woes. Truck runs 100% better now, and with 100% better mileage! So now theres two things left to do with it... fix the exhaust, cuz it sounds like a few leaks... and for some reason when I park it (possibly when Im driving) the passenger side (specificaly the front) sits up between an inch and an inch and a half (depending on EAS setting) higher. Not even all the time... just most of it. Like now its fine. But if I park it in standard or above its up. I ordered EASunlock online, to maybe recalibrate it... But could this be a bad sensor? (1999 4.0SE)
Old Aug 21, 2010 | 02:42 PM
handsome rob's Avatar
I have not heard of one going up higher than the others, more like dropping due to an air bag leak. You could have a damaged height sensor causing this, the EAS unlock will give some insight into it at least. An inch and half is a lot to be off though. Keep us updated with your progress.
Old Aug 22, 2010 | 11:12 AM
Rovin4life's Avatar
Check corrosion and or damaged connectors first.
Old Aug 23, 2010 | 06:58 AM
Vertigo RT's Avatar
where are the connectors located?
jgeorge
May 19, 2012 06:24 AM
jhammerstrom
Mar 21, 2009 06:36 PM
hooknows
Aug 29, 2006 01:58 AM
