Check Engine Light 48
Old 02-24-2008, 10:25 AM
tre976's Avatar
Default Check Engine Light 48
Apparently Im getting a crash course in fixing a 91. My CEL came on and its throwing up a 48 - which is a stepper motor. The engine revs high above 1100 then idles back to about 700 and stays there. Hopefully its just carbon build up - I havent had a chance to order the service manual yet. Where can i find the stepper motor?
Old 02-24-2008, 04:22 PM
tre976's Avatar
Default RE: Check Engine Light 48
ok well I'm replying to myself so maybe the next person that needs this answer can have it handy !
If I am wrong, someone more knowledgeable please feel free to correct me
The stepper motor -Idle air control valve can becheaper by using a 89 chevy astro van v6 as per rangerover.net - 30 bucks at autozone vs 169 for the rover verison.
you may need a crush washer when replacing the piece . that part I havent found answer to so far as a replacement.the stepper motor can be found here:
FlyingZebra34
02-22-2014 05:39 PM
RoverZebra
12-08-2012 04:27 PM
Jeremiahbullrog
04-21-2012 06:17 AM
97LANDISCOVERY
08-19-2007 04:10 PM
Quick Reply: Check Engine Light 48
