Water in my passenger foot well.
Old Aug 10, 2010 | 07:03 AM
Chris X's Avatar
Originally Posted by krazzz
The pollen filters are underneath the front cowling. What you can see from the outside is just sort of a pre-filter to keep out leaves and such. What Chris is wanting you to check are the covers on the pollen filter. If a cover came loose water could be coming in there. It would only do that during a rain or car wash event. You could test that by having somebody use a garden hose to simulate rain while you feel around to see if it starts getting wet inside.
Exactly! Thanks for following up krazzz.
RRJO - the seals on my covers are a bit dry rotted. I used clear silicone caulking around the perimeter of the covers and re-installed. Now, this isn't ideal because I'll have to take the covers back off when changing the filters, but it is working for now until I can find an alternate method. Stops the leak though!
Yours being a newer truck, perhaps the cover is a little loose or not aligned very well. If that's not the case, perhaps do the silicone or I was thinking of cutting some rubber roofing material to make a new gasket.....
Old Aug 12, 2010 | 06:52 PM
RROJ's Avatar
I will check it out and if there is anything I can't seem to handle I will give a shout out. Thanks always for the assistance.
primussucks
Sep 21, 2013 11:46 AM
acamato
Apr 12, 2013 05:44 PM
crashbump2
Mar 10, 2013 02:30 PM
sickvehicle
Jul 20, 2011 01:18 PM
takar12
Jan 6, 2006 10:38 AM
