Both banks are running lean. How many miles on your engine, when was it last tuned along with wires, when did you last clean/replace your air filter?
Check for vacuum leaks.
If you get 0733,0734 then its a maf sensor, Look for vacuum leaks such as hoses or blown out intake gaskets. Oh and check fuel trims. Its also possible you have a small leak in the exhaust but usually not both banks.
