Sponsored by: CARiD
02 disco low oil pressure
Old Feb 25, 2010 | 10:12 PM
lrlover's Avatar
4wd High
Unhappy 02 disco low oil pressure
I have a 2002 disco 2 oil pressure light came on and then engine started make a clanging noise i'm pretty sure its the pump but not 100% and help on the matter will be greatly appreciated.
Old Feb 27, 2010 | 07:46 PM
bonnettoboot's Avatar
Default pump?
I'm sure you have checked the oil level! Had the vehicle been driving, or did it happen when first starting? How many miles has it done and, how long have you had it? As it is noisy it is pretty safe to say mechanical damage has been done BUT; I would first check the actual pressure anyway, if it is low you should remove the front cover to get to the pump and inspect for damage, Once done let me know what you find!
Old Mar 11, 2010 | 10:56 AM
lrlover's Avatar
4wd High
Default oil pressure
The truck was running and i stopped within about 100 feet. The oil level is good and it has about 111000 on it and i have owned it for about 2 yrs now.
Old Mar 11, 2010 | 05:30 PM
There are 2 things that will cause low oil PSI.
1-to low on oil
2-bad oil pump
Old Mar 16, 2010 | 03:43 PM
lrobin3w's Avatar
Not shure but check with you dealer, some late model disco 2s, had an incorrectly machined block at the front cover, causing low oil psi
rewi9d
Apr 12, 2012 06:12 PM
eaglewing
Apr 16, 2011 11:06 AM
tito5590805
Oct 4, 2010 09:11 AM
DooDer
Jan 12, 2010 10:46 PM
kpmaho
Feb 23, 2005 04:39 PM
