Sponsored by: CARiD
02 freelander changed head gaskets now wont spark
Old Jan 7, 2010 | 02:12 PM
wildone24's Avatar
3rd Gear
Question 02 freelander changed head gaskets now wont spark
i changed the head gaskets on my 02 free lander and now im not getting any spark at all i have power to the coils but they wont fire any ideas will help
Old Jan 12, 2010 | 12:30 AM
tedly797's Avatar
Firts thing that comes to mind is the cam sensor on the front cylinder head, did it get routed correctly and plugged in? Are the pins okay inside the connector?
Old Jan 12, 2010 | 06:24 AM
Rovin4life's Avatar
does it have fuel pressure? pull the fuel hose and turn it on. look up codes. Seen alot of cams snap on those bad boys. check compression. oh and how were the heads themselves, pitted pretty bad? Also too hope to god the cylinder walls didnt slip out of place without the proper tools. Or the timing is off. Those engines are throwaway engines. if you are lucky to have a clean head hopefully you are lucky enough to not have coolant in the oil from a slipped liner. We have seen the coolant leak from the bottom of the engine after pulling them apart. you can use dye to see whats leaking.
jfall
Jun 9, 2022 02:52 PM
Corndogg69
Freelander
Jun 21, 2012 02:11 PM
RANDY04D2
Jun 18, 2012 09:58 PM
derek.saylor
Jan 30, 2011 12:50 AM
kjordan
Oct 22, 2008 08:21 AM
