Sponsored by: CARiD
03 Disco Coolant Woes- Need Help!
Old Mar 4, 2018 | 07:53 PM
DiscoWall's Avatar
Default 03 Disco Coolant Woes- Need Help!
Wife blew a head gasket recently due to a radiator that had sprung a leak. While driving close to our house, she saw the temp gauge go up, pulled over, cut it off, & called me. She did good. 👍 So, I get it to the house, diagnose the head gasket failure, ordered my gasket kit & radiator, & tore her down. Everything looked great save the head gasket on the right. (I suspect that it had been close to failure for sometime.) I did everything by the book. Verbatim. Fired her up upon completion, ran beautiful. Drove around town (with my computer hooked up watching my coolant temps) checking my coolant & topped it off once. After about 15 miles I stopped again too check coolant & oil. Coolant was gone & oil was over filled! Def have coolant in the crankcase. So here is my question: Just sitting in the garage, off, if I fill the coolant reservoir, it goes straight to the crankcase. I can here it making a "glug glug" sound. What in the hell is going on? Timing cover gasket? Any help would be appreciated guys. Thanks in advance.
Old Mar 7, 2018 | 07:40 PM
DiscoWall's Avatar
Seriously guys? Nobody has a thought? Discomike?
Old Mar 8, 2018 | 08:19 AM
Sixpack577's Avatar
Possibly a cracked block, or cylinder sleeve, since it's getting into the engine so quickly.
Old Mar 8, 2018 | 08:32 AM
Sixpack577's Avatar
Timing cover gasket could be possible, if the water pump gasket is blow inside, and coolant is pouring into the pan.
Old Mar 17, 2018 | 08:04 PM
Tito19's Avatar
Just to be sure. You did get the heads resurfaced, right?
Yoops Racing
Nov 30, 2014 10:40 AM
iownme
Nov 29, 2010 10:19 AM
gildedsplinters
Jan 15, 2009 12:10 PM
Goose2549
Oct 2, 2008 10:05 PM
bblizi
Jun 21, 2007 06:17 AM
