Sponsored by: CARiD
03 disco "missing" and check engine light blinking
Old Oct 6, 2013 | 02:34 PM
croller63's Avatar
Talking 03 disco "missing" and check engine light blinking
2003 Discovery 92000 miles feels like it is "missing" when in drive and at a stop light. Check engine light starts blinking at times, then quits, blinks for about 4 blinks. Getting brakes replaced on Wednesday. Haven't had codes read yet, can I drive it for two days and what might be happening. I have had the Disco for 3 years. Thanks, cindy
Old Oct 6, 2013 | 03:43 PM
pinkytoe69's Avatar
The codes will likely be misfire related.
Old Oct 6, 2013 | 03:57 PM
croller63's Avatar
Is it ok to drive for 2 days?
Old Oct 6, 2013 | 04:27 PM
jafir's Avatar
Not with the check engine light flashing. Unless you want to risk damaging the catalytic converters.
Old Oct 6, 2013 | 04:41 PM
croller63's Avatar
Thanks!
Old Oct 8, 2013 | 11:54 PM
Jason Green's Avatar
Im probably wrong but i had similar problem, The fuel pump plug turned out to be faulty. may be worth a check. its at the back under a round hatch on top of the fuel tank.
Old Oct 11, 2013 | 06:57 PM
croller63's Avatar
It was all of the electrical wiring, the guy said my car is " going" bad, the transmission is on its way out and the underbody is all rusted and that I have about a year left on my 2003 Disco with 94,000 miles. I am so sad but getting a second opinion. What do you all think?
Old Dec 3, 2013 | 12:51 PM
autoexpert's Avatar
8th Gear
Default check engine code
Hi OP,
Had you seen any code with flashing check engine light ?
If yes please check engine code.
And you should fix this error asap.
4x4trouble
May 4, 2015 05:33 PM
FlyingZebra34
Feb 22, 2014 05:39 PM
WaltNYC
Jun 9, 2011 10:08 AM
cmossman
Jul 19, 2010 03:06 PM
dgilaon4
Jul 7, 2009 08:45 PM
