03' Freelander Problem
I am a long time lurker, first time poster on this great forum.
I have a 2003 Freelander HSE and just started having big problems this morning when I tried to crank it. When I cranked it up this morning it would idle very heavy and then die after about 5 seconds. If I pressed the gas alittle it would stay cranked but would not move when I pressed the gas. I tried to crank it again and this time it stayed cranked with no gas applied but the "Service Engine Soon" and "Service Engine" lights come on and stayed on. When I press the gas it would idle down and eventually go dead. I am lost on what could be wrong all of a sudden because I drove it about 200 miles yesterday with no signs of a problem. What could be wrong?
Thank You in Advance.
Welcome JWalker !
My guess is that your issue points to a recently published TIB. It involves replacement of the electronic throttle body connector. Your vehicle is going into limp mode.
Either way, you need to get the codes pulled and a diag. This can be done by any shop with OBDII ability.
Hi.
I'm Jim Vargas from Mexico, the freelander owners in Mexico have a lot of problems for get part for the Freelander Pump Petrol. I found a sustitution for a fuel filter in Russia. I share with you and hear your advices
http://freelander.spybb.ru/viewtopic...=9&p=10#p49801
team_lunatics
Freelander
09-24-2010 12:08 PM
