Sponsored by: CARiD
03' Freelander Problem
Old Nov 25, 2005 | 04:11 PM
jwalker's Avatar
Default 03' Freelander Problem
I am a long time lurker, first time poster on this great forum.
I have a 2003 Freelander HSE and just started having big problems this morning when I tried to crank it. When I cranked it up this morning it would idle very heavy and then die after about 5 seconds. If I pressed the gas alittle it would stay cranked but would not move when I pressed the gas. I tried to crank it again and this time it stayed cranked with no gas applied but the "Service Engine Soon" and "Service Engine" lights come on and stayed on. When I press the gas it would idle down and eventually go dead. I am lost on what could be wrong all of a sudden because I drove it about 200 miles yesterday with no signs of a problem. What could be wrong?
Thank You in Advance.
Old Nov 25, 2005 | 09:30 PM
05LandRover's Avatar
Default RE: 03' Freelander Problem
where are you from? is it a cold place this time of year?
Old Nov 25, 2005 | 09:52 PM
mikemeyer0's Avatar
souns like it could be a fuel pump
Old Nov 25, 2005 | 11:17 PM
jwalker's Avatar
05LandRover - I am in Lower Alabama so it is not very cold down here even in the middle of the winter.
I hope it is not a fuel pump, is there anything I can do to get it running good enough to drive to dealer?
Old Nov 26, 2005 | 12:31 AM
Bait's Avatar
Welcome JWalker !
My guess is that your issue points to a recently published TIB. It involves replacement of the electronic throttle body connector. Your vehicle is going into limp mode.
Either way, you need to get the codes pulled and a diag. This can be done by any shop with OBDII ability.
Old Nov 26, 2005 | 04:20 AM
S. ala, cool
the south is so nice, unlike chicago where i'll be next week, i like it there in the summer, but this west texas desert boy don't like the windy city when it is cold
Old Aug 9, 2012 | 07:43 PM
Jim Vargas's Avatar
4wd High
Hi.
I'm Jim Vargas from Mexico, the freelander owners in Mexico have a lot of problems for get part for the Freelander Pump Petrol. I found a sustitution for a fuel filter in Russia. I share with you and hear your adviceshttp://freelander.spybb.ru/viewtopic...=9&p=10#p49801
Old Aug 27, 2012 | 11:43 PM
Jim Vargas's Avatar
4wd High
Hi again. I found a fuel pump for my freelander 2003, but isn't equal. The diference is a little tube conection for return to petrol. Do you think that I have problem if weld this little tube conection?
Old Aug 28, 2012 | 05:27 AM
Nyet.
team_lunatics
Freelander
Sep 24, 2010 12:08 PM
fsc
Freelander
Oct 28, 2006 05:09 PM
christer
Freelander
Oct 28, 2006 03:47 PM
freelander04
Freelander
Feb 6, 2006 12:54 AM
Terry
Freelander
Jul 23, 2005 11:18 AM
