03 RR - noisy center dash fan - low speeds
This one is tricky. Would appreciate if anyone has experienced a similar condition and was able to resolve it.
About a month ago, I noticed a noise when the fan was on the lowest two speeds. Its since continued to where its audible at the first four speeds. Beyond that, its gone.
Today I noticed that on the fourth speed, the noise pitch increases significantly when turning the steering wheel to the right. When you return the wheel when completing the turn, the noise decreases.
The fan is working on all speeds - I'd just like to find the source of the noise - is this something that can be lubricated with graphite or something else? Is the fan easily accessed?
Thx
Bob
Thx
Bob
Not the exact same problem...but similar...My fan works on on settings but the higher it gets...the more violent the vibration. To the point where my wife LOVES the heat to be on the high setting..LOL. I located the blower under the dash and hoped that maybe mounting was loose but all is secure. Maybe bad blower? 03 Disco II
Thanks in advance.
Thanks in advance.
03 range rover has the aspirator fan making noise, blow it out with an air nozzel or computer cleaner,
the disco two has crap in the fan, take it out and pull out the dogfood, leaves, mouse nest or dead baby mouse in it. if it chewed threw the blade maybe it wont still make the noise but if it does then the motor is shot from the offbalance blade.
03 disco,
The blower fan is located at your wife's feet... under the glove box. remove the 3 tree clips holding the black closure panel under the rh dash and then the one push on clip on the firewall side. remove the closure panel and you'll see the bottom of the blower motor. removed the 3 little bolts and connector to drop the fan assembley and clean out the dog food, dead mouse, Jimmy Hoffa, etc...
03 disco,
Thanks again!
Chris Miller
01-10-2013 07:50 PM
VikingDiesel
05-17-2009 10:27 PM
