Sponsored by: CARiD
04 disco All 4 tires locking up.
Old Dec 30, 2016 | 09:33 AM
Matthew Enzor's Avatar
Default 04 disco All 4 tires locking up.
Wife was taking the 04 disco to work this morning when as she put it "it just completely stopped and locked up". Called a friend with a truck and a tow rope to at least get it off the road because it was impossible to push put it in neutral and the differential in neutral and the tires were all moving at different speeds or not moving at all. So I'm stuck at work for now but when I get off and try and go deal with this what would be someone's initial guess and what can I do if anything to get it moved? I've googled the symptoms and keep reading posts about the ABS and a brake lock up is this where I should probably start? Thanks.
Old Dec 30, 2016 | 04:00 PM
abran's Avatar
No idea. Post in the D2 section and you will get plenty of responses.
Alex_M
Nov 22, 2018 12:53 AM
IndyCJ
May 28, 2013 05:31 PM
jeffh
Feb 3, 2011 01:25 PM
pvenuti
Oct 13, 2010 03:48 PM
johanba
Apr 3, 2007 11:37 AM
