Sponsored by: CARiD
1994 Land Rover Discovery Not Firing
Old Aug 24, 2012 | 06:29 PM
m.qualls89's Avatar
Default 1994 Land Rover Discovery Not Firing
Hi,
We took my brother in laws land rover and did a compression check on all the cylinders. We cleaned and re-gapped the plugs and put it back together and nothing. We checked the firing order (but if you have input on firing order feel free) and all seems correct. It will "try" to start every few strokes but only shudders. What am I missing here? Any help is GREATLY appreciated.
Old Aug 24, 2012 | 07:30 PM
1. Put a plug on the plug wire and lay on manifold. Crank. Any sparks? If none, ignition amplfier.
2. On the fuel rail on the passenger side (NAS) there is a "tire valve" where you can attach a pressure gauge. When cranking it should be 32 - 34 PSI. Can be fuse to pump, pump, fuel filter. Should hear pump run for a second or two when key is turned.
Old Aug 25, 2012 | 05:46 PM
Spark or fuel, has to be one of those.
These things never loose compression.
Old May 16, 2013 | 07:25 PM
Pyropalsy's Avatar
5th Gear
Default firing order
anyone have a link for the firing order for a 95 disc 1 ? its 3.9L
cant figure where the RAVE thing is .....
Old May 16, 2013 | 08:26 PM
You'll find the firing order on page 826 0f 873 in the workshop manual. You'll find the RAVE in several links in my signature.
Old May 16, 2013 | 09:21 PM
bump..
Firing order 1 - 8 - 4 - 3 - 6 - 5 - 7 - 2
Aff2010
Apr 16, 2011 08:03 PM
gregstil7
Jan 16, 2010 04:16 PM
casanova00
May 24, 2008 11:18 AM
lennie5936
May 7, 2008 12:00 AM
RYANHASADD
Dec 15, 2007 03:33 PM
