Sponsored by: CARiD
1996 disco belt change@#$%^&
Old Apr 22, 2008 | 07:43 AM
christians1600's Avatar
Default 1996 disco belt change@#$%^&
96 disco ive tried and searched this forum , can someone tell me the procedure for changing your belt thanks!!!
Old Apr 22, 2008 | 08:45 AM
Default RE: 1996 disco belt change@#$%^&
You are running a serpentine belt only, I believe and all that is needed is to unload the pressure from the belt tensioner with a wrench and remove the belt, pretty simple.
Old Apr 29, 2008 | 06:56 AM
i did losen the tensioner but there was no slack in the belt ,the tensioner barley moved up or down do i take the bolt all the way out????????thanks
Old Apr 29, 2008 | 07:55 AM
Put the wrench on the tensioner, the whole thing should rotate if you lean into your wrench, which will then take allow the belt to be removed.
Old Apr 30, 2008 | 09:35 AM
Landzu's Avatar
http://www.roverparts.com/TechTips/s...g_defender.cfm
you push the tensioner down.
Old May 6, 2008 | 09:17 AM
Phototone's Avatar
Just to be clear on this. You do NOT unscrew any bolt on the tensioner. You merely put your long wrench on the bolt on the tensioner pulley that is riding against the belt, and push down (away from the belt), and while holding the tensioner down and away from the belt, you take your other hand and remove the belt from something on top, such as the alternator, when you have done this you can release your pushing on the pulley and remove the belt from the rest of the pulleys.
Old May 6, 2008 | 09:21 AM
That is correct.
collin Barrows
Aug 28, 2011 07:13 AM
mr_boondoggle
Freelander
Apr 14, 2009 01:11 PM
sloppyjoe
Dec 20, 2008 07:37 PM
Robeye
Feb 28, 2008 11:32 AM
owen172
Dec 9, 2006 05:39 PM
