Sponsored by: CARiD
1997 Land Rover Disco 1 Check Engine Light on
Old May 29, 2022 | 06:45 PM
Tommy26's Avatar
Default 1997 Land Rover Disco 1 Check Engine Light on
I just bought me a 97 Disco 1 SE7 yesterday and long story short I got a little scammed. 4 codes popped up P0300 P0305 P1316 P0420. I drove it 5 hours back to where I live when I bought it yesterday and I swear I didn’t hear it misfire at all so I thought the code was a little weird. So I check the spark plugs and I did a compression test and Cylinder 5 was at 60 psi and the rest were above 150. So I poured a little oil down the cylinder to see if it was the piston ring and the psi went up to 90. So now I’m just a little puzzled, I find it odd that only one ring needs to be replaced and I’m hoping it might just be a blown head gasket. My question is can I replace the ring from the bottom and bypass taking the whole engine out and or has anyone dealt with this same issue. I’ve never worked on a Land Rover before so any helped or advice would be appreciated. I also put some sea foam and injector cleaner in her for ****s and giggles but could it also be the coil packs possibly?
Old May 30, 2022 | 01:40 PM
Harvlr's Avatar
Hi Tommy welcome to the forum. You should post your technical questions in the Disco 1 section of this forum, you’ll get a lot more views and replies there.
Old May 31, 2022 | 01:00 PM
WaltNYC's Avatar
I'd clear the codes and deal with #5 sometime later. See what happens next and deal with it as it comes.
In the meantime I'd install new plugs (NGK BPR6ES) and wires (STI 663) (coil packs are probably ok), change oil (Rotella 15-40)/ filter (WIX 1515) and air filter (WIX 42285). I'd also give the cooling system a thorough flush and change the t-stat (Stant 45858... 180 deg).
All this stuff can be purchased cheap at rockauto and/or amazon.
https://landroverforums.com/forum/di...02/#post581013
Manuals are in the google drive in my signature.
Tommy26
May 29, 2022 06:43 PM
gav70
Range Rover L322 (3rd Gen)
May 20, 2022 08:19 PM
3rd disco
Sep 28, 2015 12:46 PM
Dirt Hero
Oct 11, 2011 07:51 PM
DaveBFoto
Oct 7, 2011 08:41 AM
