Sponsored by: CARiD
1998 Disco Codes
Old Apr 12, 2010 | 08:07 PM
jostice's Avatar
5th Gear
Default 1998 Disco Codes
took to shop for no fuel..replaced fuel pump and timing chain. ran good for 1000 miles. Started running rough at idle. When driving hesitates some and when stoping the idle drops to 600rpm them flucs from 500-800. changed plugs and wires. now throwing following codes P0300, P0308, P1316.
Old Apr 12, 2010 | 08:51 PM
aemnky606's Avatar
codes are:
P0300-misfire on multiple cyl.
p0308- misfire on cyl. 8
p1316- Excessive Emissions
I had the same. Replaced plugs wires and front o2's and put the old front o2's in the back and it helped out
Old Apr 13, 2010 | 07:52 AM
The front and rear 02 sensors are different and should not be interchanged.
Jostice, what brand of plug and wire did you install? Have you checked the compression to see if #8 is low from a burned or stuck valve?
Old Apr 13, 2010 | 09:17 AM
jostice's Avatar
5th Gear
Bosch and Magna 8mm. Will check compression.
Old Apr 14, 2010 | 05:49 AM
Rovin4life's Avatar
96 to 98 have interchangeable sensors.
but yes check for compression and check for proper fuel pressure and leak down. seen a few with bad injectors.
NWROVERS
Mar 10, 2015 03:17 PM
csp
Jul 1, 2013 07:33 AM
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
