Sponsored by: CARiD
1999 Disco Series I Wheel Hub Assembly
Old Mar 9, 2016 | 06:56 PM
  #31
Tonyfnb's Avatar
Originally Posted by loanrangie
Yep, getting your hands dirty is the only way to learn. The D1 is a pretty simple vehicle really.
The feeling of the wheel coming off is probably because the hub bearing pre-load and or the swivel housing pre-load is out.
Both of these will need to be checked on re-assembly, it would be nice if a local handy forum member could give you a chop out and over see what you are doing.
That would rock! Yeah it's just super clanking sounding once I get up around 30-35
Old Mar 9, 2016 | 08:56 PM
  #32
Shiftonthefly1's Avatar
You may have a broken axle or CV. This isn't the end of the world. Get the reseal kit from Rovah farm and plan to rebuild the entire hub. It's not hard. Not too expensive. And your knowledge of the truck will drastically improve.
Old Mar 11, 2016 | 10:25 AM
  #33
WaltNYC's Avatar
this will help you.... lots of pix
https://landroverforums.com/forum/di...earings-44462/
It should probably be a sticky
Old Mar 19, 2016 | 01:51 AM
  #34
loanrangie's Avatar
Hey mate, any updates ?
Old Mar 19, 2016 | 09:37 AM
  #35
Tonyfnb's Avatar
Hey everyone! Got all my parts in I ordered (plugs, wires, this and that) so hopefully this week I will be able to do it with my buddy! I will def post photos and updates
Old Mar 19, 2016 | 04:32 PM
  #36
loanrangie's Avatar
What about the hub/bearing situation ?
Old May 4, 2016 | 10:16 PM
  #37
Tonyfnb's Avatar
WOW ok so here is the update...i FINALLY had time to get with some friends that know stuff about cars....so we jacked it up and there is ZERO play in the tire...its tight...we get under the truck and they notice my shocks are COMPLETELY shot...so thats what all the banging around is when i drove it....so we will do that this week coming up
Now my ? is...i was looking at these Pro Comp 9000's and when ordering the options are 1''-2'' lift or 5'' lift....what is just standard? like what should i put in this thing?! I'm so confused ha
Old May 4, 2016 | 10:21 PM
  #38
Tonyfnb's Avatar
like which set of 4 should i get?
http://www.4wheelparts.com/eSearch.a...Ntt=land+rover
Old May 6, 2016 | 09:31 PM
  #39
loanrangie's Avatar
1-2" lift will be fine.
Old May 7, 2016 | 10:09 AM
  #40
Tonyfnb's Avatar
Awesome I ordered some! So those will be on this coming up week then all I have left (hopefully) is the headlights aren't working but all the other lights work so wiring is messed up I guess...only the right side head light (small bulb) comes on...
Then either welding a sleeve on my muffler or putting in a new muffler
