Sponsored by: CARiD
1999 disco1 engine running poorly
Old Jul 23, 2007 | 10:20 PM
ser3's Avatar
Default 1999 disco1 engine running poorly
I have 1999 disco one engine started running poorly plugs and wires changed still running poorly getting dark outside dropped socket and happened to look under truck saw exhaust pipe under drivers side turning red. Any one have an idea 02 sensors failed not sure what to do next[>:]
Old Jul 24, 2007 | 09:21 AM
Default RE: 1999 disco1 engine running poorly
With those issues, you should have a check engine light on, have you had the codes read, if so what were the fault numbers, if not get them read today and get back to us with those numbers. In the mean time don't drive the truck much or you could cause yourself some costly $$$$.
Mike
Old Jul 24, 2007 | 05:30 PM
ser3's Avatar
Code reader PO300 PO306 PO305 PO303 P1316 P1313 ?
Old Jul 25, 2007 | 11:50 AM
ser3's Avatar
Mike -Thanks for the suggestion any idea about codes p1313 p1316?
Old Jul 25, 2007 | 01:17 PM
hendoc3's Avatar
I had a similar issue. Mine ended up being the coil pack.
Old Jul 25, 2007 | 03:13 PM
P1313 Misfire Catalyst Damage Fault Bank A
P1314 Misfire Catalyst Damage Fault Bank B
P1315 Misfire Persistent Fault
P1316 Misfire Excessive Emissions Fault
So here are you other two codes.
Who's plugs and wires are you using, have you checked for vacuum leaks?
You might want to call me.
Mike
303-862-7680
Old Jul 27, 2007 | 12:43 PM
ser3's Avatar
Mike-Thanks for the time on the phone yesterday I waited for dark could see some minor arching so I replaced all plugs and wires I cleared all codes test drove noticed a very minor stumble in the engine and a code popped up for P1313 misfire catalyst damage bank A. So it looks like I will be replacing cat "y" and at the same time I'll get all the O2 sensors replaced. Also looked and found one vacuum leak which I repairedany further thoughts about seafoam decarb of engine sounds like a good idea.JP
Old Jul 27, 2007 | 01:08 PM
That 1316 could be vacuum related, I would check the rest of you vacuum lines as well as the intake manifols seals. Don't jump into a "Y" pipe yet.
Lets talk when you get a chjance.
Mike
ajnolin
Dec 2, 2013 11:26 PM
binvanna
Jan 9, 2013 04:17 PM
faltskog5450
Feb 13, 2010 04:47 AM
buddy22
Nov 30, 2007 04:05 PM
GregHaugen
Oct 27, 2006 12:44 AM
