Sponsored by: CARiD
2001 disco 2 windshield wiper problem
Old Oct 25, 2012 | 11:24 AM
mojoboots's Avatar
Default 2001 disco 2 windshield wiper problem
Hi, new to forum and the world of Land Rovers - love mine, but have had a few problems; $900 in coolant problems the costliest...having a problem with my windshield wipers, they only work in one mode or if i hold the stalk down, also my cruise control doesn't work.
I checked fuses and was able to fix the horn - anyone else have a problem with wipers or cruise control?
Thanks,
Rob
2001 Land rover Discovery 2
Old Oct 25, 2012 | 01:16 PM
Remove the wiper switch and take it apart, clean all the contact and reinstall. If that doesn't work, time for a used or new one.
What sort of coolant problem did you have?
Old Oct 25, 2012 | 07:44 PM
Turn the steering wheel vertical so the flat bottom of it faces the wiper stalk, remove the cover on the steering column.
Remove the 2 phillips screws, pry the wiper stalk up and out.
Old Oct 28, 2012 | 10:43 AM
mojoboots's Avatar
Had what i thought to be a thermostat problem - dealer didn't fully test pressure, wound up being a seal at the engine. I live in Montana so the nearest dealer is in Spokane...makes for expensive labour at the ford dealer!
Old Oct 28, 2012 | 10:58 AM
So, stay away from the dealers, ask more questions here on line and find a local Rover shop to help you.
philipisland
Feb 4, 2013 07:13 PM
Classklown90
Dec 20, 2009 06:09 PM
Monty
Jan 27, 2008 02:19 PM
Dublz
Sep 14, 2007 12:36 PM
Oldracer
Dec 25, 2006 04:46 PM
