Sponsored by: CARiD
2001 Disco II Diagnostics Help
Old Feb 5, 2014 | 08:56 AM
Janadi's Avatar
I had the same codes.
I bought a MAF from Amazon for $33,fits perfect and works fine.
All codes gone
No need for the special tool.
Old Feb 5, 2014 | 10:13 AM
BurkhartDiscoII's Avatar
6th Gear
Okay, thanks for the advice.
I will give it a go this weekend, if the weather and Philadelphia will cooperate.
Old Feb 27, 2014 | 08:17 AM
6th Gear
I was able to use vice grips to take out the security screws, thanks for the advice Jafir.
I was able to successfully replace the MAF sensor this past weekend. I did not reset the codes and today my SES light either burnt out, or I fixed the problem
Thank YOU ALL so much for your help, I hope this post will help others in the future, like others posts have helped me.
One more thing to note: I am not so sure that I needed to remove the security screws at all. Once I removed them I realized that the electrical plug to the MAF was just a clip that needed to be pressed together on each side of the plug, and then pulled away from the MAF unit (rather tough to pull off, I had to use pliers to press both of the clips down and pull delicately as to not break the plug clips.)
rishi
Aug 17, 2012 12:19 PM
Charles King
ROAMING WITH FRIENDS
Mar 27, 2008 03:25 AM
Charles King
Mar 27, 2008 03:23 AM
The Didge
Apr 3, 2007 11:38 AM
Roverscout
Mar 26, 2006 06:47 PM
