Sponsored by: CARiD
2001 Discovery Cooling System
Old Jan 8, 2015 | 11:13 AM
rjvitullo's Avatar
4th Gear
Default 2001 Discovery Cooling System
Happy New Year All.
I have just acquired a 2001 Discovery, and trying to learn the quirks of this vehicle. I had to replace an upper radiator hose, I refilled the coolant reservoir, no heat, before I replace the Thermostat, does the system need bled, if so how?
Old Jan 8, 2015 | 03:30 PM
dusty1's Avatar
Yes. Download rave.
Raise and open reservoir, cold engine, truck on incline helps, open bleed screw, bubbles out
Repeat
Old Jan 8, 2015 | 11:27 PM
dr. mordo's Avatar
To clarify -
The RAVE is the service manual. Available here but called the Workshop Manual on that website.
Old Jan 9, 2015 | 06:16 AM
rjvitullo's Avatar
4th Gear
Thanks for the information and the link to the RAVE.
Tried bleeding it last night but still no heat so i will order a thermostat today, dont know what else it could be.
Old Jan 9, 2015 | 07:18 AM
drowssap's Avatar
when you bleed it raise the recovery tank 6-8 inches keep it filled, and do not close the bleeder at the first sign of coolant leave it open for a minute or two
Old Jan 9, 2015 | 09:03 AM
dusty1's Avatar
couple of other possibilities;
clogged heater core
poor circulation from partially gummed up radiator
do you hear a trickle/waterfall sound from the heater core? air
Old Jan 10, 2015 | 07:08 AM
rjvitullo's Avatar
4th Gear
Default fixed
Thanks for all the input, changed the thermostat and all well.
Unshriven
Apr 7, 2010 07:02 PM
jhardebeck
Jan 23, 2009 08:36 PM
johndavidrichards
Jan 21, 2009 08:06 AM
jkeving
Apr 11, 2007 11:27 PM
esaycho
Feb 7, 2007 02:25 PM
