Sponsored by: CARiD
2001 land rover dis ii/check engine
Old Sep 6, 2011 | 02:34 PM
cheezer12's Avatar
Default 2001 land rover dis ii/check engine
Need Suggestion please help.
I have a 2001 Land Rover Dis. II it has about 150,000 miles on it. The Check engine light keeps going on and off. Also the Rover acts like it
is cutting out now. It was dring just fine then all of the sudden the Check
engine light started flashing, ABS /TLC and another light stay on constant.
I went down to Autozone and got all of the codes. It had like 19 codes
it's a lot I know. The Rover act like it might have a bad Dist. cap or something had all of the plugs and plug wires replaced Rover still acts the
same. So I am at a loss now. I really love the Rover.
here are the codes
Man. codes P1590, P1412, P1415, P1300, P1884
then I have these codes P0301 #1 mis fire P0302 mis fire, P0308 Mis fire
P0305 Mis fire, P0304 mis fire. P0301 mis fire. All of the plugs and wires are
brand new. also have P0112. P0430, P0455. P0102
Thanks for any suggestions
Cheezer 12/Chris
Old Sep 6, 2011 | 08:47 PM
There is no distributor on your truck.
You need new spark plugs and spark plug wires.
If you used cheap plug wires you need to use good ones because the cheap ones are junk and will not last.
Old Dec 19, 2011 | 12:49 AM
rimasco's Avatar
Default Codes P0102 and P0455... 2001 Disco II SE (no ACE)
MIL check enine light came on.. I ran a scan which produce p0102 (maf) and p0455(evap gross leak/no flow).. I have very limited mechanical ability so I watched a video on you tube about cleaning MAFs.. bought some CRC and cleaned it.. MIL shut off and will be checking for pending codes tomorrow
2001 Disco II SE
Old Dec 19, 2011 | 04:32 AM
Most common cause of P0455 is loose gas cap, reset codes, and it will show up again in two days of use. It is one of many things that must exist for two "drive cycles" to turn on the light and set a code. Tighten cap, if it returns, replace cap. That is the cheapest part of the possible fixes for that code.
Old Dec 19, 2011 | 09:42 AM
rimasco's Avatar
Thanks Savannah.. the light shut off by itself a couple of days ago and has stayed off.. I ran a scan and p0455 still came up along with p0102 (MAF)My question to you is. Will it still send out these codes even though the MIL shut by itself?? I want to take my car for inspection already (3 months overdue) and I dont want to fail.. thank you again.. it showed pending code as well.. PS I think it was the Gas cap tripping the light at first cause the only common denominator I could think of with it coming on was gas station "fill-ups".. thank you again
Old Dec 19, 2011 | 10:27 AM
That would be a "pending code". Some codes have to repaeat four drive cycles to show up, a good many two cycles, and some are instant. IMHO there are also those that the dealership brodcasts by WIFI, to any Rovers within range (lol - not really , but it sure seems suspicious..)
butchereric
Feb 19, 2015 06:27 PM
FlyingZebra34
Feb 22, 2014 05:39 PM
fortworthcoe
Jun 4, 2008 06:39 PM
fortworthcoe
Jun 2, 2008 05:47 PM
kcirtap
Oct 12, 2007 08:32 AM
