2000 dis 2 pulling engine
I am down to pulling engine out. all 12 bolts out, 4 from torque convert out
lift is on. jack is under gearbox . should come out
what is the trick to release engine from gearbox. shaking it, pulling it, just won't seem to come out
thanks
thanks
this one has got me stuck, all bolts out according to S.M. 2 more hidden bolts not in S.M.??? I got the 2 bolts facing up in the bell. on the very bottom as part of the 12 removed. Where exactly are the secret bolts located that are not in the S.M. this baby won't come out.
thanks guys, engine is out. drowssap you are right. I had the 2 bolts already out you talked about and counted them in the 12 the s.m. says to remove, there is 12 in the bell, and 2 more not mentioned. comes out a lot more easy with all the bolts out. ahh
cheers, thanks
cheers, thanks
fortworthcoe
Jun 2, 2008 05:47 PM
