Sponsored by: CARiD
2002 RR HSE Over heating issues
Old Feb 2, 2011 | 04:58 PM
RRDude's Avatar
Default 2002 RR HSE Over heating issues
Boy where do I start. My RR started over heating several months ago. Took into the shop and they replaced the Radiator. next time replaced the Thermostat, over heated again then they rebuilt my engine. It worked good for about a month then it over heated again. Took it back tot shop. Thermostat was stuck. ran a Pressure amd Combustion check on the cooling system it failed. Added Steel Seal. Ran Test again and Passed... took it out for a test drive drove 15 miles over heated. Brought it back to shop. Reflushed system found small "white residue" in thermostat flushed the entire system again.. (didn't know what caused the white residue) The additive ???? Took it out again today drove it for an hour didnt over heat but the heater blew Cold air.. What is the problem?
PS: the work is under extended warranty so I am not paying for it. But I can't drive my Car !!
RRDude
Flyin2jz
Dec 16, 2012 12:02 AM
vALEXv
May 27, 2012 12:11 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
rhino_e28
Oct 1, 2010 12:05 AM
budley62
Jan 3, 2006 05:36 AM
