Sponsored by: CARiD
2004 Disco Cylinder Misfire Code P0304
Old Nov 7, 2011 | 10:04 AM
FLDISCO's Avatar
4th Gear
Default 2004 Disco Cylinder Misfire Code P0304
Took Disco out into the wild last weekend. Turned on truck Mon morning and it seemed to lurch a little once it was in gear moving forward. No signs of trouble once up to speed.
SES light was on. Took to mechanic and they got a P0304 code. Defined as 'engine misfire no. 4 cylinder.' Guy says something got wet in the engine and it caused the misfire. That would make some sense as I was driving through large mud puddles. (This is a Land Rover, right?!?!) Guy asked three times if I went through a large puddle as there was water stains on top of motor. Well, yes of course I did!
For past 2 days has been running fine around town. SES light now off. No sign of problem.
They say it's about $1000 with parts/labor....
Any thoughts as to how quickly I need to get this fixed??? Also all that being said is there some sort of modification I need to make to the truck in order to take it through puddles???
Thanks for the help!!!
Old Nov 7, 2011 | 10:24 AM
New plug wires, DIY, find another mechanic. P1300 and P0300 are for catalyst damage level misfires, you barely had a cough. What were they planning to do for the $1000 ?
Attached factory info on how misfire is calculated, what it means, etc.
File Type: pdf
Old Nov 7, 2011 | 10:32 AM
FLDISCO's Avatar
4th Gear
Advised replacing coils, ignition wire, sparks & wires, gasket for cylinder....
Old Nov 7, 2011 | 10:39 AM
How mechanical are you, have you done a major service on this truck along with a tune up and 8 mm silicone wires?
You should plan on asking for help, throw $$300 worth of parts and fluids at it, yourself, and save a bunch.
That being said, have you ever had your front drive shaft rebuilt or replaced yet, if not, that is even more pressing for you.
Old Nov 7, 2011 | 02:16 PM
FLDISCO's Avatar
4th Gear
Thanks for the help, all!
Somewhat mechanical but replacing drive shaft way out of my league. Could look at replacing wires if this doesnt require anything beyond pulling wires out/installing new ones.
Am still curious if this type of activity (driving through mud puddles at 25-30 miles/hour) will lead to this/and or other types of problems??? Am itching to get off-road again but hesitant given my poor track record.
Old Nov 7, 2011 | 02:45 PM
Old plug wires will allow water and even rain to cause misfires. Operating thru water at speed brings on additional challenges, if you get an air cleaner full of muddy water things happen real fast after that. So "wading" is best done at a more moderate pace.
With respect to shaft, see Propshaft Rebuild - Land Rover Forums - Land Rover Enthusiast Forum. Even if you decide to not DIY, local mechanic or sriveline shop (there are shops that just do that) can handle this for you.
Old Nov 7, 2011 | 03:31 PM
The wires are much harder to replace then a drive shaft. I would suggest you start becoming more mechanically involved with your truck or you may go broke.
There are a number of us that walk you thru many repairs on your truck if you can follow directions.
Old Nov 18, 2011 | 07:53 AM
FLDISCO's Avatar
4th Gear
Thank you both for the help! You saved me $1,000! The SES light has been off for 10 days and everything is running normally.
Would love to get more mechanical with my Rover but my two rug rats take up most of my free time for now!
Cheers and Happy Thanksgiving!
MechMac
Jun 17, 2013 09:19 AM
prroverguy
Mar 20, 2013 07:04 PM
scarrell
Nov 16, 2012 06:04 PM
WhiteLRII
Nov 20, 2008 08:02 AM
husker6:33
Jul 8, 2008 08:30 PM
