Sponsored by: CARiD
2004 Discovery head gaskets
Old Jul 9, 2008 | 08:41 AM
DickB's Avatar
4th Gear
Default 2004 Discovery head gaskets
Question- we took our 2004 Discovery into the dealer as the engine light came on. Mileage 56,000
The dealer came back and advised the two rear head gaskets were leaking.
Advised it would cost $2500.
The car is 6,000 miles out of warranty (of course)
We see a very small spots less than two 50 cent pieces on the garage
floor. Dealer advised leaking oil and coolent
The check engine light now does not come on, they also advised it needs a 02 senor fault for $275.
We plan to discuss this problem with Land Rover direct. As it does not seem it should have leaking head gaskets at 56,000 miles
Any advise would be welcomed.
Regards
Dick
Old Jul 9, 2008 | 09:27 AM
Default RE: 2004 Discovery head gaskets
Don't waste your time talking to Rover.
Go buy a can of Gunk degreaser, spray all the dirty spots on your engine then go to a local do it yourself car wash, power scrub the entire engine as well as the undercarriage then watch it daily for leaks keeping paper under your truck so you can see exactly what is dripping, oil, coolant or tranny fluid.
Get back to us and let us know what your find.
As for the cost, $1400 to $1600 is a fair price thru a small shop, not the dealer.
As for the 02 sensor, if you don't have a check engine light on, how did they determine you had an 02 problem?
Old Jul 9, 2008 | 09:52 AM
DickB's Avatar
4th Gear
Thanks we will do that, and get back to you
Thanks again
Dick
Old Jul 9, 2008 | 10:48 AM
okdiscoguy's Avatar
If your check engine light comes back on, go to a local parts store and have it read for free. Then psot back on here with the code and we can help. Might post in the Discovery section next time. You will get mire replies there...
Cheers
Old Jul 18, 2008 | 09:54 AM
DickB's Avatar
4th Gear
Thanks for the advise, cleaned engine well, new auto repair place found valve cover gaskets leaked.
Not head gaskets.
The vehcile has only 56k miles.
Thanks again
Dick
Old Jul 18, 2008 | 09:55 AM
DickB's Avatar
4th Gear
Hi cleaned engine, new repair shop found valve cover gaskets leak, not head gaskets.
Dick
Old Jul 18, 2008 | 11:12 AM
Don't let the shop replace the v/c gaskets till you check and see if the 2 bolts are loose. They usually are and can sometimes be tightened to stop the leak.
DiscoLady
Apr 15, 2013 01:19 AM
tamu_psd
Nov 6, 2012 04:20 PM
Big Jim Swade
Nov 22, 2011 02:56 PM
RROJ
Mar 26, 2011 02:37 PM
blast20
Feb 14, 2010 08:50 PM
