Sponsored by: CARiD
2005 Land Rover LR3
Old Jan 14, 2020 | 05:19 PM
Dtaylor's Avatar
4th Gear
Default 2005 Land Rover LR3
The engine light, emergency break light and ABS are eluminated on the dashboard. We have replaced the right wheel sensor, brake light sensor and installed new batteries and the lights are still eluminated.
What else can we do to clear the warnings lights off the dash board? Your assistance would be greatly appreciated.
Old Jan 14, 2020 | 05:35 PM
Friday Night Disco's Avatar
You need to erase the codes from the ECU. Go to local auto parts store and ask them to erase them
Old Jan 14, 2020 | 05:57 PM
Dtaylor's Avatar
4th Gear
Default 2005 land rover lr3
Thank you so much for your reply! I tried to clear the codes with the code machine that I purchased, but they lights are still eluminated? Any other sugguestions?
Old Jan 14, 2020 | 07:36 PM
What are the codes?
Old Jan 15, 2020 | 10:25 AM
Dtaylor's Avatar
4th Gear
Default 2005 land rover lr3 codes
What are the codes?
P0500 and C003A.
Old Jan 15, 2020 | 05:35 PM
Dtaylor's Avatar
4th Gear
P0500 and C003A.
I failed to mention that the speedometer is not working as well.
Old Jan 15, 2020 | 06:33 PM
DakotaTravler's Avatar
Well P0500 is a speed sensor fault, so that would explain the speedo and probably a great number of things. C003A is the right rear wheel speed sensor. I have no clue how vehicle speed is measure on the LR3, but if it uses wheel ABS sensors versus a sensor in the output of the trans or on the half shafts (like some cars) then I would put money on the right rear wheel ABS sensor being at fault. Since you replaced the sensor then it should not be at fault but that does not mean there is not an issue with its wiring or the ABS pick-up ring on the shaft. Did you clean the ABS pick-up ring on the CV shaft? Its toothed and if its full of stuff the sensor may not work right.
Old Jan 15, 2020 | 06:42 PM
If one sensor is out it will cause the speedo to not work and will cause a ton of lights to come on.
​​The part is cheap. Also easy to replace
jamestfl
Aug 17, 2015 01:18 PM
greenbayfan
Sep 13, 2010 08:28 PM
khandrh
Mar 6, 2008 09:03 PM
01discosteve
Sep 14, 2007 06:38 PM
quattro
Aug 17, 2006 11:32 PM
