Sponsored by: CARiD
2005 range rover cranks but no start
Old Nov 13, 2007 | 11:04 PM
mbkvette's Avatar
3rd Gear
Default 2005 range rover cranks but no start
like the title says, my car cranks but does not start, checked fuel pressure at the valve on the fuel rail, and have no pressure. im thinking there must be a fuel cut off of some sort. any ideas, and how to reset it as well?
Old Nov 14, 2007 | 08:01 AM
Default RE: 2005 range rover cranks but no start
How many miles on your truck, have you checked the fuel pump fuse and relay. The only other two things I can think of would be the inerita switch needs to be reset or you have a crank sensor failing.
Old Nov 14, 2007 | 09:21 AM
mbkvette's Avatar
3rd Gear
truck has about 23000 miles, i think it might be the inertia switch too, but i have no idea where or how to reset it. any help would be appretiated.
Old Nov 14, 2007 | 09:36 AM
They are usually located on the firewall, usually the passenger side. Looks like a round cylinder about 1" tall with a rubber boot that covers the switch.
Turn on your ignition and press the button down fo a second. if this doesn't help I would suggest you contact the dealer, you are still in warranty aren't you.
Old Nov 14, 2007 | 11:15 AM
mbkvette's Avatar
3rd Gear
i think i narrowed the prob down to the fuel pump relay not getting signal from the ecm. im starting to think its the ecm thats bad. any ideas?
Old Nov 14, 2007 | 03:19 PM
Nope, most likely the crank sensor, when they fail, the ECU won't send a signal to fire up the pump.
Aren't you under warranty, I would get it into a dealer.
dmatranga
Feb 5, 2013 12:27 AM
jrkstore43
Sep 28, 2012 04:16 PM
texmanmoore
Dec 5, 2010 12:45 PM
jennina1
Aug 15, 2009 09:45 AM
unco
Jan 28, 2007 02:56 AM
