Sponsored by: CARiD
#5 Fuse under hood (40A) Cooling Fans ?
Old Apr 20, 2015 | 09:07 AM
Southern Bawb's Avatar
Default #5 Fuse under hood (40A) Cooling Fans ?
2003 Discovery II. In the fuse box under the hood my #5 fuse (40A) (Cooling Fans) was blown. Does anyone know what these cooling fans are and where they're located? I know it's not the blower motor. It may be the electric fan in front of the radiator which I'm thinking that's the A/C condenser fan. I didn't have a 40A so I replaced it with a 30A, started the engine (cold and didn't let it warm up to operating temp due to time restraints) and turned on the A/C but that fan did not come on.
Old Apr 20, 2015 | 09:47 AM
dusty1's Avatar
Yes Ac condensing fan and it's also an auxiliary (@212 booster)
Probably your fan motor is on the way out.
Old Apr 20, 2015 | 12:58 PM
drowssap's Avatar
iirc you can reach thru the grill with a screw driver to see if its froze up.
Old Apr 20, 2015 | 01:15 PM
I can spin it with a screwdriver. Upon further research, I've read the fan doesn't turn on just because of the A/C is turned on. It takes many things into consideration like ambient temp, etc. It also comes on when the engine temp reaches 212 F. So I'll have to do more tests to see if it's working properly.
Old Apr 20, 2015 | 01:48 PM
dusty1's Avatar
ambient Ac trigger temp is in the 40s iirc
Old Apr 20, 2015 | 10:09 PM
abran's Avatar
Run 12 volts to the connector.
Old May 3, 2015 | 11:18 AM
Ran 12 volts to it straight from the battery. Fan motor didn't sound smooth and the wires heated up real fast. Removed fan and small parts fell out of fan housing. Time to replace.
edgarf23
Jun 30, 2014 07:17 AM
grandkodiak
Apr 23, 2013 06:44 PM
jmt
Dec 23, 2007 06:16 PM
stanigu
Aug 23, 2007 09:39 AM
SARAH1
Freelander
Oct 30, 2005 12:05 AM
