Sponsored by: CARiD
Any advantage in using servicable Pitman arm?
Old May 2, 2015 | 03:39 PM
Shiftonthefly1's Avatar
Default Any advantage in using servicable Pitman arm?
I'm on a quest to get my steering play gone. Replaced almost everything in the steering. I know there is still some slop from the input shaft and the ball joint on the pitman arm. My Disco had just a regular tie rod here that just popped out I'm pretty sure. This truck has a removable ball joint. Either way it's getting worked on. Wondering if there is an advantage to using either one.
Old May 2, 2015 | 07:49 PM
loanrangie's Avatar
Just means you only need to buy a service kit instead of a new pitman arm, looked after they dont wear that quick anyway.
On my original with 337K KLMS on the clock.
Old May 3, 2015 | 02:54 PM
Ok. Thanks for the input. Kit and little special tool are ordered.
wheelgarage
Nov 2, 2011 01:24 PM
jpluncford21
Mar 28, 2011 07:54 AM
'BamaBoy
Oct 17, 2010 07:08 AM
98roverguy
Aug 2, 2010 05:28 AM
Frank4
Mar 18, 2010 08:13 PM
