5687$ TOTAL REPAIR Please READ because I think I have been scammed by the Dealer
Can you guys tell me how to upload a video so you can hear the truck running, I also went out to try and start it and it started, drove around the block let it idle for 15 minutes, after putting red antifreeze in and then I got to McDonalds a 5 minute drive and it cut off in the parking lot, I asked God to let it start and get me back home and he did..
Well, Murphy's Law comes in a multi-volume set. Whe people tell me their Rover drove somewhere, parked for a short period, then would not start until it had cooled off a little; I think of the crank position sensor which can kill the spark plugs when it starts to go bad. Is coolant still being lost?
I looked up the CKP sensor is that the Bosch Crank Position Sensor ??? Lord knows I dont need to be ordering the wrong parts.
I don't trust dealerships for anything. I've heard way too many horror stories. You need to find a reputable independent guy from now on OP. I'm sorry this happened to you.
Ever since the "mechanic" at the Charlotte dealership told me over the phone that DII heater cores don't have o-rings and disputed it with me when I had my heater core apart right in front of my face I will never trust them or go to them for anything other than immediate parts.
Thank you DiscoRover I am GOING TO KEEP BIG RED FOR SPITE but I am also going to learn about my car and the CC company is in the process of getting my $$ back. I should have it in about 1 month.. On another note she broke down yesterday over heated. Had it towed home. went out this morning and tried to start her after reading through the forum, she cranked ~~~ PLEASE SEE MY LAST POSTS FOR THE ENTIRE STORY OF TODAY
:confuse d:
The crank position sensor is between $70 - $100 part. Takes about an hour of shop time. It is located on driver side rear of engine. If it is acting up, no spark. Pour cold water on it and usually it will come back to life. Will get worse.
If planning to do this yourself, take parts off carefully, every nut and bolt and spacer must go back on in exact sequence. Easier if new unit plugged in and allowed to hang down. Small hands a big plus.
I have read countless threads about head gasket failures and replacements gone wrong. Why does no one mention if the t-stat was replaced when HG work was done? Seems to me that its a small amount of money to help insure the vehicle is working properly. I happen to work at a LR dealer in MD and I know that disco was not here for work. I watched a tech who has been here way longer than me put a used engine in a disco that the old engine overheated and he told the SM there was no reason to replace the t-stat. Are you kidding me?
Agreed. Any work in the engine that could free up gunk to float about in the cooling system (gasket jobs, cooling flush, radiator swap, water pump replace ) can easily result in stuff clogging the tiny "metering" holes in the top of the D2 stat. IMHO not only should it be done, it should also be that last thing done after a cooling flush. Cheap insurance.
The coolant thru those openings mixes with cold return coolant from the radiator and warms up the stat to open. Do you really want less hot water entering the stat, so it will take longer to open fully?
Marcoadieter
Sep 26, 2010 10:46 AM
Jupiter Rover
Dec 3, 2008 10:03 AM
