Sponsored by: CARiD
89 Classic Brakes
Old Feb 2, 2008 | 08:17 PM
Classic89's Avatar
Default 89 Classic Brakes
What would cause you to replace the rotors? Isn't the usual thing that you have to do is replace the brake pads?
Old Feb 2, 2008 | 11:48 PM
WolfPack's Avatar
Default RE: 89 Classic Brakes
Overuse..as weird as that sounds. Basically heat can make them warp. Also if you have them 'turned' which basically means grinding the contact surface off. A rotor can only be turned so many times before needing to be replaced.
Rotors last MUCH longer than pads, but eventually they too will need to be replaced.
Old Feb 3, 2008 | 07:57 AM
Why are you asking??
If a shop has recommended replacing the rotors it may be because they have warn down below their minimum thickness requirements.
Old Feb 4, 2008 | 08:44 PM
Classic89's Avatar
I am just asking because I took it to a shop to get the brakes looked at because I heard a grinding noise. They told me I need all new rotors in the front and new brake pads, and then they said the back rotors have "pit rusted" is what they said. They said it would cost almost $700.00 to do it. I have taken it there before and they have been wrong so I don't really trust the price or what they have said. The only reason I took it there is because I was getting my oil changed there and there aren't any rover shops around close. I am just trying to see if I can just replace the brake pads because the rotors look fine. Any imput if helpful!
Old Feb 5, 2008 | 08:09 AM
If you have not been paying attention to your brakes and went to the metal, yes, you will need new front rotors. As for the rear, leave the rotors alone. Why don't you save yourself some money and do the brakes your self?
Old Feb 5, 2008 | 09:57 AM
Classic89's Avatar
That was my plan was to just replace the front and to do it myself! How hard is it to do myself? I have looked at my replacement manual and it doesn't look to hard. How much should it cost for me to do it on my own?
FightOnUSC79
Nov 26, 2010 09:43 AM
baysentp
Jul 24, 2007 12:25 PM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
Lighting90
ROAMING WITH FRIENDS
Nov 25, 2006 03:47 PM
