93 discovery drivers window.
My window fell off.
Right hook car, I pressed the switch to put window up last night, but it wouldn't work.
Got it home and pulled door panel off just as it was getting dark.
Had a quick look, and there's not a lot of room to get in there.
Can anyone tell me if this is common, and an easy fix?
I'm going to go look at it soon, but I have a busy day ahead, so I'm hoping this will be straight forward.
Thanks in advance. Jeff.
My window fell off.
Had to take the inside felt and rubber strip on the top of door off to see down inside, as I couldn't see from looking through the bottom holes. The whole mechanism had come off, so I put it back together, and got the glass in the channel.
Lubed up all moving parts, and its all good again.
twoxred
10-04-2021 07:07 AM
