Sponsored by: CARiD
95 Disco HELP!!!
Old Mar 4, 2018 | 08:39 AM
longshot's Avatar
The cats don’t rattle but I’m going to cut them out and check.
Old Mar 4, 2018 | 10:53 PM
XCELLER8's Avatar
Originally Posted by longshot
Thanks. I found a stock three hole plug coming out of the wiring near the coil. Would that be the one I need for the stock amp? There is also one near the distributer, hopefully the other stock plug I need.
yes most likely......originally the distributor had a "dummy" amp module attached to it as a wiring connector only, and the the wire harness from that went to the actual module mounted on the ign coil bracket
Old Mar 19, 2018 | 09:35 AM
longshot's Avatar
Thank you everyone for all the help. I managed to solve the problem by buying a stock '00 D2 with 76k miles. I am transferring the lockers, air, winch, etc.
Speed racer
Oct 11, 2008 10:56 PM
Roca316
Mar 18, 2008 11:33 AM
scottinoz
Jun 30, 2007 09:49 AM
cassie11
Jun 23, 2006 10:26 AM
