Sponsored by: CARiD
95 Discovery transfer case
Old Mar 9, 2013 | 04:46 PM
kbforn's Avatar
Default 95 Discovery transfer case
The linkage to my transfer case was not engaging. Went underneath and sprayed it w/ lubricant and was able to turn transfer switch back and forth. Jacked up front wheel and wheel turned free no matter which position switch is in. I take it that this means the transfer case is not in gear. Am I correct? What suggestions do you have? Thanks in advance. You guys have helped me out multiple times already. One other question. My manual shows to use ATF fluid for manual transmission. Is that what everyone is using also?
Ken
Old Mar 9, 2013 | 05:27 PM
If you have the 5-speed use Redline MTF.
As for the wheel turning, thats normal, the t-case is locked not the diff's.
Old Mar 9, 2013 | 05:52 PM
kbforn's Avatar
How do I know if the transfer case is engaged or not?
Old Mar 11, 2013 | 11:01 AM
kbforn's Avatar
Still looking for help. How can I tell if xfer case is engaged?
Old Mar 11, 2013 | 02:51 PM
First, you should have an indicator light come on on the cluster and or, if you slowly try to turn a tight circle the front end tires will chirp while binding up.
As for the not shifting, you may have to pull the console so you can get down to the t/case shift levers pivot and clean it out good before packing it with some grease.
BrandonS
Jan 6, 2015 09:30 AM
DerrickInMississippi
Jan 12, 2008 07:49 AM
95DiscoSE7bullitt
Oct 31, 2007 10:19 PM
br3nt
Jan 24, 2007 09:26 AM
adowgiert
Aug 27, 2005 04:53 PM
